TPI-PRO-DVI Temperature Info?
How can I ask the TPI-PRO-DVI to display it's internal temperature using Telnet?
The TPI PRO DVI reference guide lists the following as a valid telnet command: temp info
temp info is an invalid command on the tpi pro dvi with firmware v2.6.69
