WRITE FILE INDEX ISSUE
HELP!
This may take a few passes through to figure out what I'm trying to accomplish.. but essentially I am trying to write to a structure that has a max legnth of 36. This works perfectly when booking a room, but for whatever reason the write file function extends the length of the cSUBJECT in the structure to 16 after each pass. I can't figure out why for the life of me.
PROGRAM_NAME='Calendar Demo Rev 1'
(* FILE CREATED ON: 01/16/2015 AT: 08:00:17 *)
(* FILE_LAST_MODIFIED_ON: 01/29/2015 AT: 11:14:13 *)
DEFINE_DEVICE
dvMaster = 0:1:0
dvTP = 10001:1:0
dvTP_Locked = 10001:3:0
dvTP_Mtg = 10001:4:0
(* CONSTANT DEFINITIONS GO BELOW *)
DEFINE_CONSTANT
MAX_USERS = 500
MAX_MEETINGS = 36
TL_FEEDBACK = 1
TL_FEEDBACK2 = 2
TL_FEEDBACK3 = 3
(* DATA TYPE DEFINITIONS GO BELOW *)
DEFINE_TYPE
STRUCTURE _sUSERS //Presets Structure
CHAR cID[15]
CHAR cFIRST_NAME[25]
CHAR cLAST_NAME[25]
CHAR cEMAIL[50]
STRUCTURE _sMTG //Mtg Structure
CHAR cHOST_NAME[25]
CHAR cSTART_DATE[25]
CHAR cSTART_HOUR[4]
CHAR cSTART_MINUTE[4]
CHAR cEND_HOUR[4]
CHAR cEND_MINUTE[4]
CHAR cSUBJECT[50]
(* VARIABLE DEFINITIONS GO BELOW *)
DEFINE_VARIABLE
PERSISTENT _sUSERS uUSERS[MAX_USERS]
PERSISTENT _sMTG uMTG[MAX_MEETINGS]
VOLATILE CHAR cDATA[25]
VOLATILE CHAR cBADGE[20]
VOLATILE INTEGER nVALID_ENTRY
VOLATILE INTEGER nDONE
VOLATILE CHAR cHOST_NAME[25]
VOLATILE CHAR cSTART_DATE[25]
VOLATILE CHAR cSTART_HOUR[4]
VOLATILE CHAR cSTART_MINUTE[4]
VOLATILE CHAR cEND_HOUR[4]
VOLATILE CHAR cEND_MINUTE[4]
VOLATILE CHAR cSUBJECT[50]
VOLATILE INTEGER nMINUTE
VOLATILE INTEGER nHOUR
VOLATILE INTEGER nMINUTE2
VOLATILE INTEGER nHOUR2
VOLATILE INTEGER nTIME
NON_VOLATILE sINTEGER nCURRENT_HOUR
NON_VOLATILE sINTEGER nCURRENT_MIN
NON_VOLATILE sINTEGER nCURRENT_MEETING
VOLATILE LONG nTIMER[] = {500}
VOLATILE LONG nTIMER2[] = {5000}
VOLATILE LONG nTIMER3[] = {10000}
VOLATILE INTEGER nCLOSED
NON_VOLATILE DEVCHAN dcMTGs[] =
{dvTP_Locked, 1},
{dvTP_Locked, 2},
{dvTP_Locked, 3},
{dvTP_Locked, 4},
{dvTP_Locked, 5},
{dvTP_Locked, 6},
{dvTP_Locked, 7},
{dvTP_Locked, 8},
{dvTP_Locked, 9},
{dvTP_Locked, 10},
{dvTP_Locked, 11},
{dvTP_Locked, 12},
{dvTP_Locked, 13},
{dvTP_Locked, 14},
{dvTP_Locked, 15},
{dvTP_Locked, 16},
{dvTP_Locked, 17},
{dvTP_Locked, 18},
{dvTP_Locked, 19},
{dvTP_Locked, 20},
{dvTP_Locked, 21},
{dvTP_Locked, 22},
{dvTP_Locked, 23},
{dvTP_Locked, 24},
{dvTP_Locked, 25},
{dvTP_Locked, 26},
{dvTP_Locked, 27},
{dvTP_Locked, 28},
{dvTP_Locked, 29},
{dvTP_Locked, 30},
{dvTP_Locked, 31},
{dvTP_Locked, 32},
{dvTP_Locked, 33},
{dvTP_Locked, 34},
{dvTP_Locked, 35},
{dvTP_Locked, 36}
(* LATCHING DEFINITIONS GO BELOW *)
DEFINE_LATCHING
(* MUTUALLY EXCLUSIVE DEFINITIONS GO BELOW *)
DEFINE_MUTUALLY_EXCLUSIVE
(* SUBROUTINE/FUNCTION DEFINITIONS GO BELOW *)
(* EXAMPLE: DEFINE_FUNCTION <RETURN_TYPE> <NAME> (<PARAMETERS>) *)
(* EXAMPLE: DEFINE_CALL '<NAME>' (<PARAMETERS>) *)
DEFINE_FUNCTION INTEGER fnCONVERT_REQUEST (INTEGER nSTART_HOUR, INTEGER nSTART_MINUTE, INTEGER nEND_HOUR, INTEGER nEND_MINUTE)
STACK_VAR INTEGER nDURATION
STACK_VAR i
STACK_VAR x
IF(nSTART_HOUR == 1)
nSTART_HOUR = 13
ELSE IF(nSTART_HOUR == 2)
nSTART_HOUR = 14
ELSE IF(nSTART_HOUR == 3)
nSTART_HOUR = 15
ELSE IF(nSTART_HOUR == 4)
nSTART_HOUR = 16
IF(nEND_HOUR == 1)
nEND_HOUR = 13
ELSE IF(nEND_HOUR == 2)
nEND_HOUR = 14
ELSE IF(nEND_HOUR == 3)
nEND_HOUR = 15
ELSE IF(nEND_HOUR == 4)
nEND_HOUR = 16
ELSE IF(nEND_HOUR == 5)
nEND_HOUR = 17
i = ((nEND_HOUR - nSTART_HOUR)*60)
x = nEND_MINUTE - nSTART_MINUTE
nDURATION = i + x
RETURN nDURATION
DEFINE_FUNCTION INTEGER fnPROCESS_TIME (INTEGER nHOUR, INTEGER nMINUTE)
STACK_VAR INTEGER t
IF(nHOUR > 12)
nHOUR = nHOUR - 12
IF(nHOUR == 8 && nMINUTE < 15)
t = 1
ELSE IF(nHOUR == 8 && nMINUTE >= 15 && nMINUTE < 30)
t = 2
ELSE IF(nHOUR == 8 && nMINUTE >= 30 && nMINUTE < 45)
t = 3
ELSE IF(nHOUR == 8 && nMINUTE >= 45)
t = 4
ELSE IF(nHOUR == 9 && nMINUTE < 15)
t = 5
ELSE IF(nHOUR == 9 && nMINUTE >= 15 && nMINUTE < 30)
t = 6
ELSE IF(nHOUR == 9 && nMINUTE >= 30 && nMINUTE < 45)
t = 7
ELSE IF(nHOUR == 9 && nMINUTE >= 45)
t = 8
ELSE IF(nHOUR == 10 && nMINUTE < 15)
t = 9
ELSE IF(nHOUR == 10 && nMINUTE >= 15 && nMINUTE < 30)
t = 10
ELSE IF(nHOUR == 10 && nMINUTE >= 30 && nMINUTE < 45)
t = 11
ELSE IF(nHOUR == 10 && nMINUTE >= 45)
t = 12
ELSE IF(nHOUR == 11 && nMINUTE < 15)
t = 13
ELSE IF(nHOUR == 11 && nMINUTE >= 15 && nMINUTE < 30)
t = 14
ELSE IF(nHOUR == 11 && nMINUTE >= 30 && nMINUTE < 45)
t = 15
ELSE IF(nHOUR == 11 && nMINUTE >= 45)
t = 16
ELSE IF(nHOUR == 12 && nMINUTE < 15)
t = 17
ELSE IF(nHOUR == 12 && nMINUTE >= 15 && nMINUTE < 30)
t = 18
ELSE IF(nHOUR == 12 && nMINUTE >= 30 && nMINUTE < 45)
t = 19
ELSE IF(nHOUR == 12 && nMINUTE >= 45)
t = 20
ELSE IF(nHOUR == 1 && nMINUTE < 15)
t = 21
ELSE IF(nHOUR == 1 && nMINUTE >= 15 && nMINUTE < 30)
t = 22
ELSE IF(nHOUR == 1 && nMINUTE >= 30 && nMINUTE < 45)
t = 23
ELSE IF(nHOUR == 1 && nMINUTE >= 45)
t = 24
ELSE IF(nHOUR == 2 && nMINUTE < 15)
t = 25
ELSE IF(nHOUR == 2 && nMINUTE >= 15 && nMINUTE < 30)
t = 26
ELSE IF(nHOUR == 2 && nMINUTE >= 30 && nMINUTE < 45)
t = 27
ELSE IF(nHOUR == 2 && nMINUTE >= 45)
t = 28
ELSE IF(nHOUR == 3 && nMINUTE < 15)
t = 29
ELSE IF(nHOUR == 3 && nMINUTE >= 15 && nMINUTE < 30)
t = 30
ELSE IF(nHOUR == 3 && nMINUTE >= 30 && nMINUTE < 45)
t = 31
ELSE IF(nHOUR == 3 && nMINUTE >= 45)
t = 32
ELSE IF(nHOUR == 4 && nMINUTE < 15)
t = 33
ELSE IF(nHOUR == 4 && nMINUTE >= 15 && nMINUTE < 30)
t = 34
ELSE IF(nHOUR == 4 && nMINUTE >= 30 && nMINUTE < 45)
t = 35
ELSE IF(nHOUR == 4 && nMINUTE >= 45)
t = 36
RETURN t
DEFINE_FUNCTION sINTEGER fnFILL_CALENDAR (INTEGER nCURRENT_HOUR, INTEGER nCURRENT_MIN)
STACK_VAR INTEGER x
STACK_VAR INTEGER nINDEX
FOR(x=1; x<=MAX_LENGTH_ARRAY(uMTG); x++)
IF(LENGTH_STRING(uMTG[x].cSUBJECT) > 0)
IF(uMTG[x].cSUBJECT == uMTG[x].cSUBJECT)
ON[dvTP_Locked, x]
ELSE
OFF[dvTP_Locked, x]
IF(nCURRENT_HOUR > 12)
nCURRENT_HOUR = nCURRENT_HOUR - 12
nINDEX = fnPROCESS_TIME(nCURRENT_HOUR, nCURRENT_MIN)
IF(LENGTH_STRING(uMTG[nINDEX].cSUBJECT) > 0)
SEND_COMMAND dvTP, "'^TXT-1,0,',uMTG[nINDEX].cSUBJECT"
RETURN TRUE
ELSE
SEND_COMMAND dvTP, "'^TXT-1,0,Vacant'"
RETURN FALSE
DEFINE_FUNCTION INTEGER fnPROCESS_REQUEST (INTEGER nINDEX, INTEGER nNUM_MTGs)
STACK_VAR INTEGER i
fnREAD_FILE_MTG('New_Mtg.csv')
IF(LENGTH_STRING(uMTG[nINDEX].cSUBJECT) < 1)
FOR(i=1; i<=nNUM_MTGs; i++)
RETURN TRUE
ELSE IF(LENGTH_STRING(uMTG[nINDEX].cSUBJECT) > 1)
RETURN FALSE
BREAK;
nINDEX++
DEFINE_FUNCTION fnRead_BadgeID (CHAR cFILENAME[])
LOCAL_VAR SLONG slFILE_VAL
slFILE_VAL = FILE_OPEN(cFILENAME,FILE_READ_ONLY)
IF(slFILE_VAL < 0)
SELECT
ACTIVE(slFILE_VAL == -2): SEND_STRING 0, "'Invalid Path'"
ACTIVE(slFILE_VAL == -3): SEND_STRING 0, "'Invalid Value'"
ACTIVE(slFILE_VAL == -5): SEND_STRING 0, "'I/O Error'"
ACTIVE(slFILE_VAL == -14):SEND_STRING 0, "'Max Files Open'"
ACTIVE(slFILE_VAL == -15):SEND_STRING 0, "'Invalid File Format'"
ELSE IF(slFILE_VAL > 0)
LOCAL_VAR SLONG slVAL
LOCAL_VAR INTEGER i
LOCAL_VAR CHAR cBUFF[2048]
FOR(i=1; i<=MAX_LENGTH_ARRAY(uUSERS); i++)
slVAL = FILE_READ_LINE(slFILE_VAL,cBUFF,MAX_LENGTH_ARRAY(cBUFF))
uUSERS[i].cID = REMOVE_STRING(cBUFF,',',1)
SET_LENGTH_STRING(uUSERS[i].cID,LENGTH_STRING(uUSERS[i].cID)-1)
uUSERS[i].cFIRST_NAME = REMOVE_STRING(cBUFF,',',1)
SET_LENGTH_STRING(uUSERS[i].cFIRST_NAME,LENGTH_STRING(uUSERS[i].cFIRST_NAME)-1)
uUSERS[i].cLAST_NAME = REMOVE_STRING(cBUFF,',',1)
SET_LENGTH_STRING(uUSERS[i].cLAST_NAME,LENGTH_STRING(uUSERS[i].cLAST_NAME)-1)
uUSERS[i].cEMAIL = cBUFF
FILE_CLOSE(slFILE_VAL)
DEFINE_FUNCTION fnREAD_FILE_MTG (CHAR cFILENAME[])
IF(slFILE_VAL < 0)
SELECT
LOCAL_VAR INTEGER i
STACK_VAR INTEGER x
FOR(i=1; i<=MAX_LENGTH_ARRAY(uMTG); i++)
uMTG[i].cHOST_NAME = REMOVE_STRING(cBUFF,',',1)
SET_LENGTH_STRING(uMTG[i].cHOST_NAME,LENGTH_STRING(uMTG[i].cHOST_NAME)-1)
uMTG[i].cSTART_DATE = REMOVE_STRING(cBUFF,',',1)
SET_LENGTH_STRING(uMTG[i].cSTART_DATE,LENGTH_STRING(uMTG[i].cSTART_DATE)-1)
uMTG[i].cSTART_HOUR = REMOVE_STRING(cBUFF,',',1)
SET_LENGTH_STRING(uMTG[i].cSTART_HOUR,LENGTH_STRING(uMTG[i].cSTART_HOUR)-1)
uMTG[i].cSTART_MINUTE = REMOVE_STRING(cBUFF,',',1)
SET_LENGTH_STRING(uMTG[i].cSTART_MINUTE,LENGTH_STRING(uMTG[i].cSTART_MINUTE)-1)
uMTG[i].cEND_HOUR = REMOVE_STRING(cBUFF,',',1)
SET_LENGTH_STRING(uMTG[i].cEND_HOUR,LENGTH_STRING(uMTG[i].cEND_HOUR)-1)
uMTG[i].cEND_MINUTE = REMOVE_STRING(cBUFF,',',1)
SET_LENGTH_STRING(uMTG[i].cEND_MINUTE,LENGTH_STRING(uMTG[i].cEND_MINUTE)-1)
uMTG[i].cSUBJECT = cBUFF
DEFINE_FUNCTION fnWRITE_FILE_MTG(CHAR cFILENAME[])
LOCAL_VAR SLONG slFILE_VAR
LOCAL_VAR INTEGER i
LOCAL_VAR SLONG slRESULT
slFILE_VAR = FILE_OPEN(cFILENAME,FILE_RW_NEW)
IF(slFILE_VAR > 0)
cBUFF = "uMTG[i].cHOST_NAME,',',uMTG[i].cSTART_DATE,',',uMTG[i].cSTART_HOUR,',',uMTG[i].cSTART_MINUTE,',',uMTG[i].cEND_HOUR,',',uMTG[i].cEND_MINUTE,',',uMTG[i].cSUBJECT"
slRESULT = FILE_WRITE_LINE(slFILE_VAR,cBUFF,LENGTH_STRING(cBUFF))
FILE_CLOSE(slFILE_VAR)
SEND_STRING 0,"'GOOD FILE CLOSED ',ITOA(FILE_CLOSE(slFILE_VAR))"
ELSE
SEND_STRING 0,"'BAD FILE OPEN ',ITOA(FILE_CLOSE(slFILE_VAR))"
(* STARTUP CODE GOES BELOW *)
DEFINE_START
TIMELINE_CREATE(TL_FEEDBACK, nTIMER, 1, TIMELINE_ABSOLUTE, TIMELINE_REPEAT) //Half Second
TIMELINE_CREATE(TL_FEEDBACK2, nTIMER2, 1, TIMELINE_ABSOLUTE, TIMELINE_REPEAT) // 5 Seconds
TIMELINE_CREATE(TL_FEEDBACK3, nTIMER3, 1, TIMELINE_ABSOLUTE, TIMELINE_REPEAT) //60 Seconds
(* THE EVENTS GO BELOW *)
DEFINE_EVENT
DATA_EVENT[dvMaster] //Master Data Event
ONLINE:
SEND_COMMAND dvTP, "'ADBEEP'" //When online, BEEP!
STRING:
IF(FIND_STRING(DATA.TEXT, "'GOOD FILE CLOSED'", 1))
PULSE[nCLOSED]
DATA_EVENT[dvTP]
STRING:
STACK_VAR INTEGER x
SEND_STRING 0, "'FROM TP: ', DATA.TEXT"
SELECT
ACTIVE(FIND_STRING(DATA.TEXT, 'Button 16-', 1)):
REMOVE_STRING(DATA.TEXT, 'Button 16-', 1)
cBADGE = DATA.TEXT
IF(LENGTH_STRING(cBADGE == 11))
fnRead_BadgeID('Badge_IDs.csv')
FOR(x=1; x<=MAX_LENGTH_ARRAY(uUSERS); x++)
IF(cBADGE == uUSERS[x].cID)
SEND_COMMAND dvTP, "'@PPN-New Mtg'"
SEND_COMMAND dvTP, "'@PPK-Authorization'"
SEND_COMMAND dvTP, "'@PPK-Invalid Entry'"
SEND_COMMAND dvTP_Mtg, "'^TXT-1,0,',uUSERS[x].cFIRST_NAME,',',uUSERS[x].cLAST_NAME"
ON[nVALID_ENTRY]
cHOST_NAME = "uUSERS[x].cFIRST_NAME,' ',uUSERS[x].cLAST_NAME"
SEND_COMMAND dvTP_Mtg, "'^TXT-2,0,',DATE"
BREAK;
ELSE
SEND_COMMAND dvTP, "'@PPN-Invalid Entry'"
OFF[nVALID_ENTRY]
WAIT 40
SEND_COMMAND dvTP, "'PAGE-Locked'"
ACTIVE(FIND_STRING(DATA.TEXT, '@PPF-Authorization;Locked', 1)):
SET_LENGTH_STRING(cHOST_NAME, 0)
SET_LENGTH_STRING(cSTART_DATE, 0)
SET_LENGTH_STRING(cSTART_HOUR, 0)
SET_LENGTH_STRING(cSTART_MINUTE, 0)
SET_LENGTH_STRING(cEND_HOUR, 0)
SET_LENGTH_STRING(cEND_MINUTE, 0)
SET_LENGTH_STRING(cSUBJECT, 0)
SEND_COMMAND dvTP_Mtg, "'^TXT-3,0,'"
SEND_COMMAND dvTP_Mtg, "'^TXT-4,0,'"
SEND_COMMAND dvTP_Mtg, "'^TXT-5,0,'"
SEND_COMMAND dvTP_Mtg, "'^TXT-6,0,'"
SEND_COMMAND dvTP_Mtg, "'^TXT-11,0,'"
SEND_COMMAND dvTP_Mtg, "'^TXT-12,0,'"
SEND_COMMAND dvTP_Mtg, "'^TXT-13,0,'"
ACTIVE(FIND_STRING(DATA.TEXT,'KEYB-',1)):
REMOVE_STRING(DATA.TEXT,'KEYB-',1)
cDATA = DATA.TEXT
ACTIVE(FIND_STRING(DATA.TEXT,'KEYP-',1)):
REMOVE_STRING(DATA.TEXT,'KEYP-',1)
IF(nTIME == 1)
nHOUR = ATOI(DATA.TEXT)
ELSE IF(nTIME == 2)
nMINUTE = ATOI(DATA.TEXT)
ELSE IF(nTIME == 3)
nHOUR2 = ATOI(DATA.TEXT)
ELSE IF(nTIME == 4)
nMINUTE2 = ATOI(DATA.TEXT)
PULSE[nDONE]
BUTTON_EVENT[dvTP_Mtg, 3]
PUSH:
TO[BUTTON.INPUT]
nTIME = 1;
RELEASE:
WAIT_UNTIL(nDONE)
cSTART_HOUR = ITOA(nHOUR)
SEND_COMMAND dvTP_Mtg, "'^TXT-3,0,',cSTART_HOUR"
IF(nHOUR >= 8 && nHOUR < 12)
SEND_COMMAND dvTP_Mtg, "'^TXT-5,0,AM'"
ELSE
SEND_COMMAND dvTP_Mtg, "'^TXT-5,0,PM'"
BUTTON_EVENT[dvTP_Mtg, 4]
PUSH:
nTIME = 2;
RELEASE:
WAIT_UNTIL(nDONE)
cSTART_MINUTE = ITOA(nMINUTE)
IF(nMINUTE == 0)
cSTART_MINUTE = "'00'"
SEND_COMMAND dvTP_Mtg, "'^TXT-4,0,',cSTART_MINUTE"
BUTTON_EVENT[dvTP_Mtg, 11]
PUSH:
nTIME = 3;
RELEASE:
WAIT_UNTIL(nDONE)
cEND_HOUR = ITOA(nHOUR2)
SEND_COMMAND dvTP_Mtg, "'^TXT-11,0,',cEND_HOUR"
IF(nHOUR2 >= 8 && nHOUR2 < 12)
SEND_COMMAND dvTP_Mtg, "'^TXT-13,0,AM'"
ELSE
SEND_COMMAND dvTP_Mtg, "'^TXT-13,0,PM'"
BUTTON_EVENT[dvTP_Mtg, 12]
PUSH:
nTIME = 4;
RELEASE:
WAIT_UNTIL(nDONE)
cEND_MINUTE = ITOA(nMINUTE2)
IF(nMINUTE2 == 0)
cEND_MINUTE = "'00'"
SEND_COMMAND dvTP_Mtg, "'^TXT-12,0,',cEND_MINUTE"
BUTTON_EVENT[dvTP_Mtg, 6]
PUSH:
RELEASE:
WAIT_UNTIL(nDONE)
cSUBJECT = cDATA
SEND_COMMAND dvTP_Mtg, "'^TXT-6,0,',cSUBJECT"
BUTTON_EVENT[dvTP_Mtg, 10] //reserve a new meeting
PUSH:
LOCAL_VAR INTEGER x
LOCAL_VAR INTEGER INDEX
LOCAL_VAR INTEGER nDURATION
LOCAL_VAR INTEGER nNUM_MTGS
LOCAL_VAR INTEGER ACCESS
INDEX = fnPROCESS_TIME(nHOUR, nMINUTE)
nDURATION = fnCONVERT_REQUEST(nHOUR, nMINUTE, nHOUR2, nMINUTE2)
nNUM_MTGS = (nDURATION/15)
ACCESS = fnPROCESS_REQUEST(INDEX, nNUM_MTGS)
IF(LENGTH_STRING(cSUBJECT) > 0)
OFF[dvTP_Mtg, 16]
IF(ACCESS == 1)
FOR(x=1; x<=nNUM_MTGS; x++)
uMTG[INDEX].cHOST_NAME = cHOST_NAME
uMTG[INDEX].cSTART_DATE = DATE
uMTG[INDEX].cSTART_HOUR = cSTART_HOUR
uMTG[INDEX].cSTART_MINUTE = cSTART_MINUTE
uMTG[INDEX].cEND_HOUR = cEND_HOUR
uMTG[INDEX].cEND_MINUTE = cEND_MINUTE
uMTG[INDEX].cSUBJECT = cSUBJECT
fnWRITE_FILE_MTG('New_Mtg.csv')
INDEX++
IF(x == nNUM_MTGs)
BREAK;
SEND_COMMAND dvTP, "'@PPX-New Mtg'"
ELSE IF(ACCESS == 0)
SEND_COMMAND dvTP, "'@PPN-Error'"
ELSE
ON[dvTP_Mtg, 16]
BUTTON_EVENT[dvTP, 4] //Cancel the current meeting
PUSH:
LOCAL_VAR INTEGER i
LOCAL_VAR INTEGER nDURATION2
LOCAL_VAR INTEGER nNUM_MTGs2
LOCAL_VAR INTEGER nLINE
nLINE = fnPROCESS_TIME(nCURRENT_HOUR, nCURRENT_MIN)
nDURATION2 = fnCONVERT_REQUEST(ATOI(uMTG[nLINE].cSTART_HOUR), ATOI(uMTG[nLINE].cSTART_MINUTE), ATOI(uMTG[nLINE].cEND_HOUR), ATOI(uMTG[nLINE].cEND_MINUTE))
nNUM_MTGs2 = (nDURATION2/15)
FOR(i=1; i<=nNUM_MTGS2; i++)
SET_LENGTH_STRING(uMTG[nLINE].cHOST_NAME, 0)
SET_LENGTH_STRING(uMTG[nLINE].cSTART_DATE, 0)
SET_LENGTH_STRING(uMTG[nLINE].cSTART_HOUR, 0)
SET_LENGTH_STRING(uMTG[nLINE].cSTART_MINUTE, 0)
SET_LENGTH_STRING(uMTG[nLINE].cEND_HOUR, 0)
SET_LENGTH_STRING(uMTG[nLINE].cEND_MINUTE, 0)
SET_LENGTH_STRING(uMTG[nLINE].cSUBJECT, 0)
nLINE++
IF(i == nNUM_MTGs2)
BREAK;
BUTTON_EVENT[dcMTGs]
PUSH:
STACK_VAR INTEGER BIC
BIC = BUTTON.INPUT.CHANNEL
ON[dvTP, 6]
ON[dvTP, 7]
IF(LENGTH_STRING(uMTG[BIC].cSUBJECT) > 0)
SEND_COMMAND dvTP, "'^TXT-2,0,',uMTG[BIC].cSUBJECT,' ',uMTG[BIC].cSTART_HOUR,':',uMTG[BIC].cSTART_MINUTE,' - ',uMTG[BIC].cEND_HOUR,':',uMTG[BIC].cEND_MINUTE"
ELSE
SEND_COMMAND dvTP, "'^TXT-2,0,Meeting room available'"
WAIT 50
OFF[dvTP, 6]
OFF[dvTP, 7]
BUTTON_EVENT[dvTP, 3]
PUSH:
STACK_VAR INTEGER y
y = fnPROCESS_TIME(nCURRENT_HOUR, nCURRENT_MIN)
IF(LENGTH_STRING(uMTG[y].cSUBJECT) > 0)
SEND_COMMAND dvTP, "'^TXT-3,0,',uMTG[y].cSUBJECT"
ELSE
SEND_COMMAND dvTP, "'^TXT-3,0,There is no meeting to cancel...'"
TIMELINE_EVENT[TL_FEEDBACK]
nCURRENT_HOUR = TIME_TO_HOUR(TIME)
nCURRENT_MIN = TIME_TO_MINUTE(TIME)
TIMELINE_EVENT[TL_FEEDBACK2]
nCURRENT_MEETING = fnFILL_CALENDAR(nCURRENT_HOUR, nCURRENT_MIN)
TIMELINE_EVENT[TL_FEEDBACK3]
(* THE ACTUAL PROGRAM GOES BELOW *)
DEFINE_PROGRAM
[dvTP, 1] = (nCURRENT_MEETING == 1)
(* END OF PROGRAM *)
(* DO NOT PUT ANY CODE BELOW THIS COMMENT *)
When you say "extends cSubject to 16" do you mean it truncates the 50 characters to 16?
Can you post the contents of the file?
it truncates to 16 yes, the file doesnt show any characters, although they may be blank spaces. Thoughts?
I'd change that to "LENGTH_ARRAY" and see if you get different results.
I remember getting inconsistent results with the "LENGTH_STRING" command.
Since it is an Axcess command, best to avoid it anyhow.
Also, you may want to SEND_STRING 0 the "slRESULT" var to see how many characters are actually getting written to the line.
Whoa... I've never seen that command before... or the VARIABLE_TO_XML command.
Thanks for teaching me something new. What does it convert the structure to? A CSV line?
Interesting...
Really? Doesn't that defeat the purpose for using XML?
Not really, its more to do when you nest a structure, you know, put one sturcture within another.
