ELO NEW 22-inch Desktop touchpanel driver 2201L
I tryed ELO 22 touchpanel 2201L(zero bezel type) using USB , but TPI-PRO-DVI doesn't work.
Select ELO touch /ELO19 touch Driver, both doesn't work.
One previous model 2200L using USB/serial works TPI-PRO-DVI without problems.
Touch driver has changed ? specification shows IntelliTouch -> IntelliTouch Plus.
Is there someone success ELO 2201L on TPI-PRO-DVI ?
  • JasonS
    JasonS If I had known it was going to be that kind of party...
    Driver selection is only for serial touch panels. There are several versions of firmware that are specific for the Elo panels. It can be a pain to get them to work. Tech support suggests disconnecting the Elo USB, updating firmware, and after TPI reboots pluging USB back in. Another thing that I have occasionally had to do with Touch Screens of multiple brands, is connect it to a computer first, get it working there and then it will work with the TPI.
  • koozoo
    koozoo Junior Member
    thanks for advice
    Newest touchdriver which download from AMX web site, suite 22 ELO touchpanel using USB.
    ET2201L-8UWA-0-MT-GY-G IntelliTouch Plus OK
    ET2201L-8UWA-0-ZB-GY-G iTouch NG
    ET2201L-2UWA-0-MT-GY-G Projected Capacitive NOT tried
