ni2000 lan port
haneyrhaneyr Junior Member
I have an older NI2000 that today the LAN port stopped communicating with the touch panel. I see that both port lights keeping blinking but there is no link to the switch or directly to the touch panel. I can connect to the NI2000 by serial port but not by LAN. Any ideas besides throw it away.
    Yeah, if the NIC is indeed dead it's probably easier to just grab a new one off ebay.
  • haneyrhaneyr Junior Member
    Problem turned out to be very strange. The system works in my test bench setup. But when I used a smaller 4 port LAN hub I got no connection from the CV12 touch panel and the NI2000. I tried two other hubs and got the same problem. But when I went to a 16 port hub it all worked. So not sure what the problem is or with what device. But I will use the working hub and go from there for now.
