Regarding MVP5200i
Hello All, I am having problems with the MVP 5200I. I want to set a Ip to the Panel but it does not goto the setup page( Protected setup) While long holding the Center button of the wheel. Do you have any suggestions?
I have removed the battery and put it back again. The panel starts but i cannot goto the Configuration window.
I appreciate your help.
Thanks in Advance
Thanks in Advance
You can't even use the USB connection because it is an ethernet gateway that isn't set to DHCP ny default.
