Benq MX850UST Control
Cedric
Cedric Junior Member
Hi,
I'm trying to control from RS232 a Benq MX850UST
On the RS232 control documentation from Benq
- Baud Rate Default in 115200 bps
- Data Length 8 bit
- Parity Check None
- Stop Bit 1 bit
- Flow Control None
Power ON ASCII command : *pow=on#
the code is :
dvProj_RS232 = 5001:1:0
DATA_EVENT[dvProj_RS232]
online:
send_command data.device,'SET BAUD 115200,N,8,1 485 DISABLE'
SEND_STRING dvProj_RS232,"*pow=on#"
I had try the different hexa command on the forum, but doesn't seem to work.
If anyone have any suggestion or any other protocol, thanks.
  • ericmedley
    In Netlinx you use single quotes for ASCII strings
    Should be
    SEND_STRING dvProj_RS232,'*pow=on#'
  • Cedric
    Hi,
    Thanks, had try both in fact (with single and double quote)
    I just receive a file from benq with all the rs232 general protocol, if someone need this file, just contact me.
    Also on this file for the power on the ASCII command is :
    <CR>*pow=on#<CR> so
    SEND_STRING dvProj_RS232,'<CR>*pow=on#<CR>'
    and on Hexa:
    SEND_STRING dvProj_RS232,"$0D,$2A,$70,$6F,$77,$3D,$6F,$6E,$23,$0D"
    Steel not working
    I will try to make an other rs232 cable, just to be sure, had take one already made.
  • ericmedley
    Ummm.. The <CR> is a $0D hex.
    So, you have to make a hybrid string
    SEND_STRING dvProj_RS232,"$0d,'*pow=on#',$0d"
    They really should have covered this in Programmer 1 class.
  • Cedric
    Yes, we had covered this in programmer1
    the problem was coming from the wire
    The one I was using for the test was working on other device but not the benq
    Had to make a ''special one'' for this connection
    Master -- Benq
    1--1
    2--3
    3--2
    4--4
    5--5
    6--6
    7--7
    8--8
    9--9
    on the other cable only RX TX and GnD are connect
    Now it's working can turn on/off from ASCII or hex
    Thanks for your help
