Mitsubishi Datawall S-70HE75CA
Hi,
I am trying to control Mitsubishi S-70HE75CA datawall.Which is having 4 cubes is loop. First cube's RS-232 input port is connected to NI-4100 and output of first cube is coonected to the RS-232 input of the 2nd cube. Similarly for cube 2,3 and 4. I tried so many commands and combinations but not able to control even a single cube.
commands i am using are,
SEND_STRING dvDatawall,"$30,$30,$21,$0D" //power on
SEND_STRING dvDatawall,"$30,$30,$22,$0D" //power oFF
and i also tried
SEND_STRING 5001:1:0,"'00vP 0',$0Dh" //Power off
Also attaching the protocol file. Command string format and commands are mentioned on the page no 8 and 23 respectively.
anu suggesations plz
  • Jim Johnson
    Jim Johnson Junior Member
    Yet another great protocol document!
    In one section the command ID is 2 characters long and in another section it is 4 characters long.
    I would try this:
    SEND_STRING 5001:1:0,"'0001vP 0',$0D" //cube 1 Power off
    SEND_STRING 5001:1:0,"'0002vP 0',$0D" //cube 2 Power off
    etc.
    it is unclear in my brief reading if:
    SEND_STRING 5001:1:0,"'0000vP 0',$0D" //all Power off
    would do a global power off for all the cubes in the chain. It might be worth a try.
    Make sure that the cubes are addressed properly, check baud rates, check the wiring, Ya know all the usual suspects.
    ...Jim...
  • Thanks Jim, Will try the same :-)
    Sent from my Nexus 4 using Tapatalk
