Cisco C** v2_1_3 Module
I am using the latest cisco codec module from AMX. In the word doc, under command control, the following is stated in CAMERAPRESET-<preset> colum:
"This command uses xcommand Preset Activate of the codec. This means it will also set the input sources. If you want to set the position only, please see the CAMERAPRESET_POS command."
I am looking for this CAMERAPRESET_POS command and it is nowhere to be found in the word doc. Can someone point out what I am missing?
