Lifesize Icon 600
erwinm
I'm trying to control a Lifesize Icon 600 with the modules of AMX. I'm having a lot of trouble with this. I can't readout the addressbook, only the favorites. Pan/tilt-speed levels don't work, when a call is disconnected, the feedback still says 'connected', when there is a message on the screen, i can't control te set until the message times-out.
I'm getting a little desperate.
Does anybodys have experiance with controlling the LifeSize Icon 600? I'm hoping to get some advice or examples.
I used the duet Module for another lifesize and had the same problem. I just coded around it.....no choice!
If you want a simple solution you can mimic the remote buttons using 232 commands and use the OSD to guide the user. -
Hello,
I´m working with this ICON600 too and I have a lot of problems too...
My Big Problem is that I cannot use the DTMF. Have anyone some Ideas??? ( Is very important for my Project because the most users are using a virtual-vc-room with a DTMF-Passwort!)
About your Adressbook-search. You have to switch the D:P:S from 41001:1:1 to 41001:2:1 in your Phonebook-module. (the first Port is for the Local phonebook;like Favorites and the second Port ist for the Corporate Phonebook)
Example:
Define_Device
vdvLifeSizeIcon = 41001:1:0 // The COMM module should use this as its duet device
vdvLifeSizeIcon2 = 41001:2:0 // Line 2
dvLifeSizeIcon = 0:3:0 // ETHERNET CONTROL
DEFINE_CONSTANT
DEV vdvDev[] = {vdvLifeSizeIcon}
DEV vdvDev2[] = {vdvLifeSizeIcon,vdvLifeSizeIcon2}
DEV vdvDev_PB[] = {vdvLifeSizeIcon2}
DEFINE_MODULE 'LifeSize Icon PhonebookComponent' phonebook(vdvDev_PB, vdv_TP, nLifeSizeIcon, nPhonebookPages)
THX a lot & greetings !!!
DK -
Controll a Icon 800
Does anyone know if this modul ist working with the Lifesize Icon 800 Device as well ?
