TPI Pro - Double tap issue with Iiyama usb touchscreen - any ideas?
Dubbledex
Dubbledex Junior Member
HI guys,
Just wondering if anyone is still using the TPI pros? I have bought some new iiyama screens to replace my ELO's that are all popping like crazy. However When I have the command to make the preview screen go to full screen it often seems to see two taps instead of one, and you get stuck in this double tap loop. Does anyone know how I could fix this? I think the preview screen to large screen is done via the TPI controller. Perhaps if I ran everything by the NI3100 and put in some sort of ignore? I guess the difficulty is it might then ignore presses like when you are doing the volume. Maybe it would just make the volume a bit slower?
If anyone has any ideas it would be great if you could share them with me :)
Regards,
David
