Polycom HDX-8000
prakash
Member
Does anyone having Polycom HDX-8000 serial Power ON/OFF Commands?
Sent from my Nexus 4 using Tapatalk
I don't think you have Power On/Off Control.
You have "wake" and "sleep" -
Jim Donachiue wrote: »I don't think you have Power On/Off Control.
Yes I checked, I have Wake and Sleep
SEND_STRING dvPolycom, "sleep register"
Is this ok? -
Are you using the AMX Module for the HDX9002?
If so, I think you can simply do:
ON[vdvHDX, POWER_ON]; //Module does Send_String dvHDX, "'wake', $0D";
and
OFF[vdvHDX, POWER_ON];//Module does Send_String dvHDX, "'sleep', $0D";
If I am wrong, please correct me anyone. -
Jim Donachiue wrote: »Are you using the AMX Module for the HDX9002?
and
Yes I am using AMX Module for the HDX9002
Thanx for helping me -
and
DEFINE_DEVICE is
dvPolycomHDXSerial = 5001:1:0 // RS232 port 1 real device
vdvPolycomHDX1Serial = 41002:1:0 // Serial virtual device 1
vdvPolycomHDX2Serial = 41002:2:0 // Serial virtual device 2
vdvPolycomHDX3Serial = 41002:3:0 // Serial virtual device 3
vdvPolycomHDX4Serial = 41002:4:0 // Serial virtual device 4
vdvPolycomHDX5Serial = 41002:5:0 // Serial virtual device 5
vdvPolycomHDX6Serial = 41002:6:0 // Serial virtual device 6
vdvPolycomHDX7Serial = 41002:7:0 // Serial virtual device 7
vdvPolycomHDX8Serial = 41002:8:0 // Serial virtual device 8 -
When user selects VC:
Wake up Codec, if it is not already Awake.
if ( !([vdvPolycomHDX1Serial, POWER_ON]) )
ON[vdvPolycomHDX1Serial, POWER_ON];
...Route VC to displays, etc...
On System Shutdown:
Put Codec to Sleep, if it is Awake
if ( ([vdvPolycomHDX1Serial, POWER_ON]) )
OFF[vdvPolycomHDX1Serial, POWER_ON]; -
For some reason (and this may have been the early revisions of the module), channel 27 and 28 didn't work very reliably to wake and sleep the codec. I've gotten into the habit of doing SEND_COMMAND vdvCodec,"'PASSTHRU-wake'" and 'sleep' for that particular function.
I will agree with nickm.
Change the previous code to://When user selects VC Call: Define_Function VCStartup() { //Wake up Codec, if it is not already Awake. if ( !VCStarted ) { Send_Command vdvPolycomHDX1Serial, "'PASSTHRU-wake'"; VCStarted = True; } //...Route VC to displays, etc... } //On System Shutdown Call: Define_Function VCShutdown() { //Put Codec to Sleep, if it is Awake if ( VCStarted ) { Send_Command vdvPolycomHDX1Serial, "'PASSTHRU-sleep'"; VCStarted = False; } }
