Can I use a Modero TP with an access system - non-Netlinx
I have a customer with an old access card frame and they want to add a Modero TP. I don't think this is doable but thought I'd ask. So, is it possible to use a Netlinx device (ie Modero TP)with a system running access (ie: an accent3 Pro)?
--D
1) Put the Accent3 into slave mode (Tech Note 158)
2) Plug the Accent3 into the Axlink port of the NI-700.
3) Convert the Axcess code into Netlinx code.
This thread has some additional info:
http://www.amxforums.com/showthread.php?2892-Netlinx-and-Axcess-Masters-together-is-it-possible
