Transfer Aborted - Incompatible Version
javedwahid
I'm trying to transfer .irl files to a DVX2155HD on ports 9 and 10. I keep getting a "Transfer Aborted - Incompatible Version" message. Anyone know what the problem is here and how to fix it?
Javed
Javed
Ports 9 and 10 are not valid IR ports for the DVX-2155HD. You need to use ports 5-8.
From the specifications tab found here:
http://www.amx.com/products/DVX-2155HD.asp
• IR/Serial:
• (4) 8-pin 3.5 mm (female) captive-wire connector
• 4 IR Transmit / 1-way Serial ports
• NetLinx Ports 5-8
• Supports high-frequency carriers up to 1.142 MHz
• 4 IR/Serial data signals can be generated simultaneously -
You're right, it was 5 and 6. Thanks for the help.
Anytime...
