DGX Input Status
I apologize if I've overlooked the answer elsewhere, but a forum search hasn't turned up anything and I've checked the docs, so here goes. Is there a way to check input signal status (specifically HDMI) on a DGX frame, similar to ?VIDIN_STATUS on the DVX hardware? I don't see anything similar in any of the documentation, and I don't have the hardware on hand to do any testing.
Matt
Matt
I wanted to know which output an Rx was plugged into (for portable carts in boardrooms) and since there's no easy command to find that out, tech support directed me to the DGX Shell commands, which can be sent to and received from a Netlinx program (apparently). I was on site and under pressure so I didn't pursue it, but the Shell interface might be your best bet. The Shell interface resides on port 3 (5002:3:0).
