Send_Command Response From a MAX-CSE
Raphayo
Hi All,
i'm currently trying to get response from a MAX-CSE.
SEND_COMMAND ENCODER, 'GET STREAM STATUS'
The unit is set has
ENCODER 32001:1:0
i have create a buffer
CREATE_BUFFER ENCODER, ENCODER_TBUF
The ENCODER_TBUF is set to 100
char ENCODER_TBUF[100]
i'm currently using the com port of the MAX-CSE ENCODERS232 32001:2:0 and the command and response works perfectly for the comport.
but someone can help me to figure out why i can't receive any response from the unit when i'm trying to get information from the Port 1 of the MAX-CSE.
Thanks.
The unit is set has
ENCODER 32001:1:0
Thanks.
What is the physical device number?
It should be set in a range 5001-5999
Then port 2 is used for serial commands/strings.
So if it's set to 32001 then 32001:2:0 is the serial port -
If the serial ports are up at 32,000s then they are in the dynamic device range. They should be set back down. 5001 is the standard but anything below 9999 should be okay.
The Serial Port works fine, i'm able to send/receive command from the serial port of the MAX-CSE.
The problem is i sent a command to the Port 1 (Streaming Command) of MAX-CSE. The command is working when i set parameter
SEND_COMMAND ENCODER,"'PLAY'"
SEND_COMMAND ENCODER,"'SET ASOURCE MIC'"
but the port didn't return feedback when i sent a get command. those get command are supposed to return a response of the actual status.
SEND_COMMAND ENCODER,"'GET VSOURCE'" should return VSOURCE = COMP
Does it mean i need to set the the MAX-CSE to and address between 5000-5999 to be able to get response from port 1
Thanks -
Looking at the manual
http://www.amx.com//assets/manuals/MAX-CSE.CSD.OperationReferenceGuide.pdf
port 1 is for stream commands
port 2 is for 232 commands
can you post some code? It might help figure out what you're trying to do
command responses should come back on port 1 - how are you capturing them?
you should have:data_event[ENCODER] { command: { send_string 0, "'Command Received: ', data.text" //process response here } }
then for your 232 responses:data_event[ENCODERS232] { string: { send_string 0, "'String Received: ', data.text" //process response here } } -
Problem Solved
Thanks ijed,
i was using String: instead of Command:
now it's working.
by using data.text i don't need to use create_buffer anymore? -
It depends on the type of device that is talking to you. Any kind of an external device, you want to use a buffer because it is not guaranteed you will get an entire command in one packet. (Hence if you are only using DATA.TEXT you'll lose information) If we are talking about another AMX device, like a touchpanel or anything on the Axlink bus, then DATA.TEXT is sufficient.by using data.text i don't need to use create_buffer anymore? -
Also, just so you know... Data.text has a 2K size limit. With Create_Buffer you can go well beyond that size. So, for things like web page interfacing, large XML files and so forth you will need to go with C_B to avoid truncated messages.
