CRC16 Modbus Problem
Cameron Davidson
CamDav
I'am having problems with the checksum of this piece of kit any help well much appreciated.
It's been a bit of a *****.
I have tried this.
DEFINE_FUNCTION CalculateCRC (CHAR cData[255])
STACK_VAR LONG nCRC_Hi LONG nCRC_Lo INTEGER nIndex
nCRC_Hi = ($FF)
nCRC_Lo = ($FF)
SEND_STRING 0:0:70,"'CRC Hi, ',ITOA(nCRC_Hi),' CRC Lo, ',ITOA(nCRC_Lo)"
FOR(nIndex = 1 ; nIndex < LENGTH_STRING(cData) ; nIndex ++)
nCRC_Hi = nCRC_Lo ^ cCRCHiArray[cData[nIndex]]
nCRC_Lo = cCRCLoArray[cData[nIndex]]
SEND_STRING 0:0:70,"'For Loop ',ITOA(nIndex),' CRC Hi, ',ITOA(nCRC_Hi)"
SEND_STRING 0:0:70,"'For Loop ',ITOA(nIndex),' CRC Lo, ',ITOA(nCRC_Lo)"
nCRC_Data_Lo = nCRC_Lo
nCRC_Data_Hi = (nCRC_Hi << 8)
SEND_STRING 0:0:70,"'End CRC Lo, ',ITOA(nCRC_Data_Lo)"
SEND_STRING 0:0:70,"'End CRC Hi, ',ITOA(nCRC_Data_Hi)"
cScaler_Command_Buffer = "$BE,$EF,$1A,$0C,$00,$00,$00,$3F,$00,$00,$00,$02,$00,$00,$00,$00,$00,$00,$00"
CalculateCRC (cScaler_Command_Buffer)
I Should get $19,$d7 back.
Any Help Please.
Cameron.
I have tried this.
nCRC_Hi = ($FF)
nCRC_Lo = ($FF)
Any Help Please.
Cameron.
The main issue I think was you were probably throwing index 0 errors in netlinx a lot, I'd do it like this:
PROGRAM_NAME='test' DEFINE_DEVICE dvMaster = 0:1:0 DEFINE_CONSTANT Char cCRCHiArray[] = { $00, $C1, $81, $40, $01, $C0, $80, $41, // removed many lines of constant data for brevity $01, $C0, $80, $41, $00, $C1, $81, $40 } Char cCRCLoArray[] = { $00, $C0, $C1, $01, $C3, $03, $02, $C2, // Removed many more lines of constants here too... $82, $42, $43, $83, $41, $81, $80, $40 } DEFINE_VARIABLE Volatile Char cTestString[255] Volatile Char cCRC_Return[2] Define_Function Char[2] CalcCRC(Char cDataIn[]) { Stack_Var Char cData[15000] // Whatever the longest possible message will be Stack_Var Char cCRCHi,cCRCLo,cDatum,cIndex cData = cDataIn // So we can be destructive without changing cDataIn cCRCHi = $FF cCRCLo = $FF While(Length_String(cData)) { // Pull off the first data byte cDatum = Get_Buffer_Char(cData) cIndex = cCRCHi BXOR cDatum // We add 1 to all our array indexes, since unlike C, 0 is not our first array element. cCRCHi = cCRCLo BXOR cCRCHiArray[cIndex+1] cCRCLo = cCRCLoArray[cIndex+1] } Return "cCRCLo,cCRCHi" } DEFINE_PROGRAM Wait 100 { cTestString = "$BE,$EF,$1A,$0C,$00,$00,$00,$3F,$00,$00,$00,$02,$00,$00,$00,$00,$00,$00,$00" cCRC_Return = CalcCRC(cTestString) SEND_STRING dvMaster,"'End CRC Hi, $',ItoHex(cCRC_Return[2])" SEND_STRING dvMaster,"'End CRC Lo, $',ItoHex(cCRC_Return[1])" }
This function returns the CRC bytes all ready to be concatenated into your send packet like:cData=$BE,$EF,$1A,$0C,$00,$00,$00,$3F,$00,$00,$00,$02,$00,$00,$00,$00,$00,$00,$00 Send_String dvDevice,"$BE,$EF,$1A,$0C,$00,CalcCRC(cData),$3F,$00,$00,$00,$02,$00,$00,$00,$00,$00,$00,$00"
Apparently this is one weirdo protocol trying to CRC it's own header and CRC byte positions. -
Many Thanks
Thanks Greg
That is fantastic i will try this on Monday.
Its a very strange way indeed. thats why i was a bit confussed.
Thanks Again
Cameron
