Extron IPL T S1 via LAN
This is probably an easy question, but I'm just getting back into AV programming don't remember a lot of stuff.
I'm trying to connect to an Extron IPL T S1 via LAN, the box then controls a display via RS-232. My problem is connecting to the IPL T S1 from netlinx code. Am I supposed to use IP_CLIENT_OPEN? and how do I sent the commands to, maybe SEND_COMMAND? Need general help in setting this case up.
Javed
Javed
dv_IP_Port = 0:< 3 or greater>:system
You use IP_CLIENT_OPEN following the help file for how to initialize the comm.
Then you send_string to send commands to the unit. It will respond back and it will generate a data_Event:String. Commands to that device are for internal AMX commands to the port.
Also, if you don't have any traffic with the device for a minute or so it will probably disconnect. Actually, I think the AMX will disconnect. If you have your program send some sort of query to the port every 30 seconds or so, it should stay open almost forever.
