SMTP Email weirdness
Don DeLong
I have a Netlinx system that, among other functions, serves as a master monitor for several interconnected paging systems, each of which have their own Netlinx master connected via M2M, and recently added email functionality that sends status updates to a list of addresses stored in an array. The message format is simple, listing the time & date the master sent the message, then text describing the status of each system on the network, followed by a bit of text explaining why the email was sent (system showing alarm, warning, status change, or user interaction).
This is triggered by a timeline that fires every 6 hours, plus any time status changes of one of the systems, or when an admin manually sends a test email from a virtual TP.
Everything works OK, except at the end of each email, there is sometimes a bunch of random junk appended, which looks like part of a previous email. I can't nail down why this would happen, as the message is assembled in a STACK_VAR inside the function that sends the email.
Has anyone had any experience with this? Master is running FW v4.1.373, code for email functionality is below:
Don
DEFINE_FUNCTION fnSEND_EMAIL_STATUS(CHAR sTEXT_TO_APPEND[64])
STACK_VAR INTEGER nSYSTEM_NUMBER
STACK_VAR INTEGER nALARM_LEVEL
STACK_VAR INTEGER nPROBLEM_SYSTEM
STACK_VAR INTEGER nADDRESS_LOOP_COUNTER
STACK_VAR CHAR sEMAIL_TEXT[1024]
STACK_VAR CHAR sEMAIL_SUBJECT[64]
IF(nENABLE_EMAIL)
sEMAIL_TEXT = "
'Corporate PA Monitor Status Report',$0D,$0A,$0D,$0A, //START OF MESSAGE
DATE,' ',TIME,$0D,$0A,$0D,$0A //MASTER'S DATE & TIME
nALARM_LEVEL = STATUS_OK //CLEAR nALARM_LEVEL
IF(nPANEL_ONLINE[1] == FALSE) //IF PANEL IS OFFLINE
IF(nALARM_LEVEL < STATUS_ALARM)
nALARM_LEVEL = STATUS_WARNING
sEMAIL_TEXT = "sEMAIL_TEXT, 'COMMAND CENTER TP OFFLINE',$0D,$0A"
IF(nPANEL_ONLINE[2] == FALSE) //IF PANEL IS OFFLINE
sEMAIL_TEXT = "sEMAIL_TEXT, 'BB-28 TP OFFLINE',$0D,$0A"
IF(nPANEL_ONLINE[3] == FALSE) //IF PANEL IS OFFLINE
sEMAIL_TEXT = "sEMAIL_TEXT, 'SA-1 SECURITY TP OFFLINE',$0D,$0A"
IF(nPANEL_ONLINE[4] == FALSE) //IF PANEL IS OFFLINE
sEMAIL_TEXT = "sEMAIL_TEXT, 'C-1 TP OFFLINE',$0D,$0A"
IF(nPANEL_ONLINE[5] == FALSE) //IF PANEL IS OFFLINE
sEMAIL_TEXT = "sEMAIL_TEXT, 'SA-1 VISITOR TP OFFLINE',$0D,$0A"
IF(nPANEL_ONLINE[6] == FALSE) //IF PANEL IS OFFLINE
sEMAIL_TEXT = "sEMAIL_TEXT, 'SA-4 VIRTUAL TP OFFLINE',$0D,$0A"
sEMAIL_TEXT = "sEMAIL_TEXT, $0D,$0A,$0D,$0A"
FOR(nSYSTEM_NUMBER = 1;nSYSTEM_NUMBER <= 27;nSYSTEM_NUMBER++)
IF(AUDIO_SYSTEM_ARRAY[nSYSTEM_NUMBER].dvDEVICE.SYSTEM) //IF DEVICE IS DEFINED
sEMAIL_TEXT = "sEMAIL_TEXT,AUDIO_SYSTEM_ARRAY[nSYSTEM_NUMBER].sSYSTEM_NAME,': '" //APPEND SYSTEM NAME, COLON, SPACES TO TEXT
SWITCH(AUDIO_SYSTEM_ARRAY[nSYSTEM_NUMBER].nSYSTEM_STATUS)
CASE STATUS_OK:
sEMAIL_TEXT = "sEMAIL_TEXT,'SYSTEM OK',$0D,$0A"
CASE STATUS_WARNING:
nPROBLEM_SYSTEM = nSYSTEM_NUMBER
sEMAIL_TEXT = "sEMAIL_TEXT,sSYSTEM_LAST_ERROR[nSYSTEM_NUMBER],$0D,$0A" //APPEND LAST ERROR (CURRENT ERROR)
CASE STATUS_ALARM:
IF(nALARM_LEVEL = STATUS_ALARM)
nPROBLEM_SYSTEM = SYS_MULTIPLE
ELSE
sEMAIL_TEXT = "sEMAIL_TEXT,sTEXT_TO_APPEND" //APPEND TEXT PASSED TO FUNCTION TO END OF REPORT
SWITCH(nALARM_LEVEL)
CASE STATUS_OK:
sEMAIL_SUBJECT = "'Corporate PA Monitor Status Report: ALL SYSTEMS OK'"
sEMAIL_SUBJECT = "'Corporate PA Monitor Status Report: WARNING-',AUDIO_SYSTEM_ARRAY[nPROBLEM_SYSTEM].sSYSTEM_NAME"
CASE STATUS_ALARM:
IF(nPROBLEM_SYSTEM == SYS_MULTIPLE)
sEMAIL_SUBJECT = "'Corporate PA Monitor Status Report: ALARM-MULTIPLE SYSTEMS'"
ELSE
sEMAIL_SUBJECT = "'Corporate PA Monitor Status Report: ALARM-',AUDIO_SYSTEM_ARRAY[nPROBLEM_SYSTEM].sSYSTEM_NAME"
FOR(nADDRESS_LOOP_COUNTER = 1;nADDRESS_LOOP_COUNTER <= 20;nADDRESS_LOOP_COUNTER++)
IF(sEMAIL_ADDRESS_LIST[nADDRESS_LOOP_COUNTER]) //IF AN ADDRESS EXISTS
SMTP_SEND(dvMAIL_HANDLER,sEMAIL_ADDRESS_LIST[nADDRESS_LOOP_COUNTER],sEMAIL_SUBJECT,sEMAIL_TEXT,NULL_STR)
IF(nDEBUG)
SEND_STRING 0, "'SENDING EMAIL TO: ',sEMAIL_ADDRESS_LIST[nADDRESS_LOOP_COUNTER]"
IF(nDEBUG)
SEND_STRING 0, "'EMAIL SUBJECT: ',sEMAIL_SUBJECT"
SEND_STRING 0, "'EMAIL BODY: ',sEMAIL_TEXT"
Don
I have seen this before, I believe it is a known issue. What version of firmware are you using? I remember it being an issue at one point, but I don't remember seeing it recently.
Firmware is v4.1.373 which is current, although it appears there is a hotfix available. I will have to talk to TS about getting it so I can try it next time I'm on-site. Like I said, the issue isn't critical as all the message gets through, but it does look weird to see a snipped of text from a previous message appended to the end, plus sometimes random characters.
