Home DigiTech Forum GNX Forum Achive GENERAL Member Patch Review
So how does this work? Patch review guidelines
Patches are posted on the old Digitech forum. This is accessible at www.digitech.com/soundcomm. Click on Guitar products, then select the GNX unit you have to go to the patches. You can create a user name (it helps to have a similar one to the one you have here), and upload patches. You can also upload a sound sample and post a description, which is helpful to other users.
Because the actual message board of the old forum is no longer used, patches are reviewed here. Here are some suggestions for posting patches to review:
1. Provide a link to where the patch is downloaded. People are much more likely to get it this way.
2. Provide a description of your patches here. For example, what artists/songs does it sound like? Are there any particular effects you're adding that aren't readily apparent? Are there controller assignments other users should be aware of? What are the different amp channels for? What kind of guitar/amp were you using to create these patches?
3. IMPORTANT! List the unit that you're using. GNX3/4 users have no use for GNX3000 patches; not all GNX3 patches can be converted to GNX4 patches; etc.
If you are requesting patches, also provide some detail (see 2 above); this way, people who have a similar setup and have a patch are more likely to help you. Also, do a search first. You might not like the sound of some of the patches already available, but try to tweak them - keep in mind, different guitar/amp combinations require adjustment to be made to patches. If you do not find what you're looking for in the SoundComm, look here:
http://www.digitech.com/cgi-bin/guitarone.pl
http://www.digitech.com/cgi-bin/guitarworld.pl
