CD control via rs232
Hello everyone!
I am pretty new to soundweb london and have a question if I can actually contol cd/mp3 player (play, stop, fastforward, rewind) that has rs232 port via blu 16 with a blu 8 controller. I know there is an application of a school gymnasium that implements pretty much the same set up. But I am kinda slow with how you make those serial strings.
Thanks for any input!
Stas
    This is done using a Serial Trigger object placed in the Logic Configuration.
    Information about this object is found in the London Architect help file. You can also learn about the Serial Trigger and the Logic Configuration from the great training videos here: http://video.soundwebtraining.com/
    In brief, wire up some Logic Sources to the Serial Triggers, then drag the Logic Source buttons onto the BLU-8 buttons. If you need to make the Logic Source buttons turn off automatically, then set an Auto Off time in the Properties.
    If you need a proper answer then you can either call/email tech support in the US or contact you local distributor in your country. See the Contact page of the BSS Audio website.
