How to use Auxillaries in Soundweb original/ Architect
Does any one know about his topic.?
    In Soundweb Designer you can enable the Aux Buses by Right-Clicking a Mixer object and selecting \"Properties\". In the \"Properties\" you can enable up to two Aux Buses. If you Double-Click the Mixer object you will open the Default Control Panel where you will see the \"Aux Buses\" tab. Selecting this tab will display the Aux Send controls for each channel of the Mixer. The Aux Sends are post-fader by default, but you can make them pre-fader by enabling the \"Aux Pre Fade\" button.
    In HiQnet London Architect you can enable the Aux Buses by selecting the Mixer object and adjusting the \"Number of Auxes\" setting in the Properties Window. You can have up to four Aux Sends. If you Double-Click the Mixer object you will open the Default Control Panel where you will see the \"Aux\" button. Clicking this button will display the Aux Send and Aux Return controls. The Aux Sends are pre-fader by default, but you can make them post fader individually by enabling the \"Post\" button.
    All of this information is available in the Help file included in both Soundweb Designer and HiQnet London Architect.
