Power on/off Blu-80 over RS232
Would it be possible to power up the Blu-80 over the RS232 or over a trigger signal ?
If so how do I do it ?
  • Well, that depends on what you mean by \"powering up\"?
    Obviously you can't power off any unit completly and expect it to respond to a control command!
    So, option 1: program a \"stand-by mode\" as a parameter preset (like: mute all outputs) and trigger that with rs232 or whatever you fancy.
    Option 2: use a mains power relay to turn on/off the Blu.
    Which method to use is entierly up to you and what you think suites your application.
    /Chris
