Map config transfer
Hi again
Is there any way to transfer map configs builded on a 9000 to a 9088ii?
Regards
Kaibenson
  • To copy everything from a 9000 to a 9088, open the 9000, select all of the processing objects and wires, hit CTRL+C. Open the 9088, hit CTRL+V.
    If you're wanting to actually move a config from one device to another and keep the custom control panels functional, forget it. There's no way to do it. You'll have to copy it to the 9088 and then rebuild any custom control panels, presets, control port assignments, etc.
    Dan
  • There are so many times I get asked if you can do something within Soundweb original. If the asked operation can't be done, I virtually every time get to say \"but you can in Soundweb London!\"
    This would have been another of those times. I just want to make a point of how much more capable the London system is because sometimes we forget to see all the details.
    Sorry, this didn't actually have anything to do with the original question. :oops:
    Cheers
    Chris
