Labeling of outputs for the source matrix object?
Is it possible? Curious why this would be possible on the Matrix Router, but then not the Source Matrix, it would be nice so the labels flow through after the Source Matrix.
  • select the processing object (source matrix) go to properties, change the 'display signal name' to Yes. It will now show the selected source as a signal name.
    Is that what you mean....
    Rob
  • You can't label the outputs on a Source Matrix because the signal name from the input passes to the output. On a Matrix Router (or Mixer), it's not possible to pass the input name to the output because there could be multiple inputs all going to one output. Therefore, the signal name coming out of the object has to be created by the object.
    Dan
